my car idles at 2000 rpm help me
i have an 1989 mustang 5.0 and ever since i replaced the intake and throttle body the car has been idling at 2000 rpm. i adjusted the idle screw..not the problem. i was thinking it is a vacumm line becasue everytiem i shut the car off i hear a hissing noise. when i took off the intake i also noticed some cracked vacumm hoses bud put them on anyway. could it be the vacumm leak or a faulty iac motor or sensor or any other sensor that has to do wiht the air intake
RE: my car idles at 2000 rpm help me
OK, there are 2 places on the tbody to adjust the idle, you have the throttle screw, which you said you adjusted. Is it a new tbody? Even if it isn't check the throttle-stop screw, it's on the outside of the tbody with the linkage, the throttle plate might not be closing all the way.
it doesnt make sense, since there is a valve inside that opens and closes to regulate how much air enters the engine. it shouldnt matter which way it is on there.
and I didnt know there is an aftermarket vendor for those, who makes it?
I am jsut curious, not trying to be an ***.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
