heater core is bad, is there any other place to block it off besides the fire wall??
#21
RE: heater core is bad, is there any other place to block it off besides the fire wall??
ORIGINAL: mustangman1
well thanks to everyone's help on this site i found out my heater core is bad, i live in so. cal. so i dont care about the heat and i wanna just block it off....but im haveing trouble working on it by the firewall. A friend told me to follow the "water pipe" to the water pump and i can block it off there.....but it looks like the "pipe" runs to other places beside the heater core (like the throttle body) so can someone tell me if there is any other places to block it off besides the firewall?????
#22
ORIGINAL: 5.0_faithful
When my heater core went bad I joined the inlet and outlet hoses at the firewall using Brass ****** Pipe Fittings. This allows you to join the two hoses securely and without leaking when You use good hose clamps. Also brass is better because there wont be the possibility of dirty rust flowing through your engine like a regular pipe might have. It worked great for me even with agressive driving! Hope this helps!!
#23
ORIGINAL: badtzmaru
I think is time to start inversting in a chiltons repair manual.
http://www.worldcatlibraries.org/wcp...4da09e526.html
Good luck, I also live in San Diego, SOCAL area.
#24
i always cut stubborn hoses off with a box cutter and then pull them off. i know this sound nasty but if u knaw on the new hose a little it will slip in place easier with a little oil in the hose!!
#25
ORIGINAL: odogg88
if i remember correctly the piece you need is dayco part #80433cs, this will connect them
#26
anyone know who carries dayco parts?
ORIGINAL: odogg88
#28
ORIGINAL: rmodel65
just pull the dash its not that hard www.mustangsteve.com has info about doing it!
#30
thanks
ORIGINAL: odogg88
i got mine from autozone.
