Piston Notching!
Piston Notching!
Hi I was wondering if anyone here notched there pistons. I rented the piston notcher from isky cams, and was wondering if anyone had any tips or anything for me. Advice would be much appreciated.
-Jared
-Jared
RE: Piston Notching!
Been there done that. Take it to a machine shop and get it done right. If you do insist on doing it yourself. Get a couple rolls of duct tape, a grease gun, a good drill and a shop vac.
Pack the grease around the cyliner wall to *try* and prevent flakes/chips from getting in the rings. Duct tape across the entire side of the engine to keep the flakes/chips from getting in other cylinders. Vacuum out the chips from the spark plug hole and then when you pull the head. Be patient, it's going to take a while.
Good luck!
Good luck!
ORIGINAL: Jared_blown5.0
no it is not out of the car. and thank you grimace
Here I found a link with pictures you can print and take with ya..
http://www.forcefedhighperformance.com/tech_Isky.htm
Good luck!
uberstang1
09-20-2015 06:42 PM
