what will it run?
RE: what will it run?
Traction is a major problem, if i brake torque it to near stall, it break the tires loose, throws the car a little sideways, and takes off when it finally decides that the tires have had enough abuse. If i punch it from idle it is a similar result, but not to the same extent, and without throwing the car into a slight slide. Would upper and lower control arms help me out with this at all? also, what is the best way to launch an automatic?
btw, my car also has an a/c delete kit (i forgot, i guess thats how you know its not summer time, if it was summer it would have been the first mod on the list)
its all traction...If you cant hook you will run high times...I was on all season BFG radail t/a, I couldnt hook for crap....If i had some slicks it would have been a differnt story, and I would run what the car was capible of...13.6ish.
