Well, my new wishlist
im young and starting college(and have a job) so this might take awhile to finish but.....
I would like to have a good daily-driver(but be able to lay the smack-down when I choose to ) HAS to have A/C, seeing 115+ temps out here no modifications to the inside(tearing the carpet and rear seats, etc) or outside. Under the hood would be a completely different story and hopefully some five-O experts can help me out, this is what i've compiled so far:
and....
Theres a 5.0 racing class here in Mexicali(Hugh city right across the border in Mexico) that im gonna start participating in, only limits are how deep your pockets go, and its only 5.0 Powered vehicles, doesnt matter if its a miata or F150 crewcab
Engine
*Dart Sportsman Block
*RHS 200ccs, 64cc chamber (unsure)
*Custom Grind Cam
*GT40 Lower Intake, ported extensively
*347 Stroker kit, Forged Internals, H-beams, dished pistons
*Megasquirt Standalone
*80MM Throttle Body
*Some CAI (mounts into the fenderwell)
*Long Tubes(Ceramic)
*Catless H-pipe
*Ignition System
Fuel System
*Walbro 255lph Fuel Pump
*Ford Racing 60lbs Injectors
*Adj FPR
Drivetrain
*T56 viper spec w/.5 OD
*Ford Racing 3.55 w/ Ring and Pinion Installation Kit
*Spec Stage II+ Clutch Kit
*Spec Aluminum Flywheel
*MGW Short-Throw
*Steeda Quadrant & Firewall Adjuster
Suspension
*Strange Shocks & Struts
*Eibach Sportlines
*Edelbrock Adj. Upper Control Arms
*Maxiumum Motorsports Lower Control Arms
*Caster/Camber Plates
*Full Length Subframe Connectors
*4-lug/disc brakes all around
*03 Cobra Rims wrapped in BFG KDWs
welp, almost a year after I joined and made my wishlist, it has certainly changed various times, I've had some BIG setbacks but now I've back on track
and finally am able to start work on my 5.0.
Above is what I *think* is my finally list,[8D][8D][8D]
and....
Engine
*Custom Grind Cam
*80MM Throttle Body
*Catless H-pipe
*Ignition System
Fuel System
*Adj FPR
Drivetrain
*MGW Short-Throw
Suspension
*Eibach Sportlines
RE: Wishlist
If you plan on doing alot of mods you should consider converting to Mass Air. Converting it is easier than dealing with the problems that will show once you start doing major modifications.
https://mustangforums.com/m_842395/tm.htm
RE: Wishlist
Nah, I would keep the shorties. Also, LT's are not as loud as shorties. I had MAC LT's w/ a MAC Pro-Chamber and American thunders and my SLP LM 1's are almost just as loud alone as my whole setup that was on my 88 GT.
RE: Wishlist
^^ They do sound deeper..... but just not as loud. Heres a soundclip of my 88 GT
MAC LT's
MAC Pro-Chamber
Flowmaster American Thunders
BTW, disregard the loud whistle...
http://dropshots.com/day.php?userid=...8&ctime=204614
It did sound pretty nice though
MAC LT's
MAC Pro-Chamber
RE: Wishlist
Yea, that was my 88 when it was together and running...
Heres the beast now...
I just baught a really nice 10 X 20 tent last week so I can continue to work on it again. I have the whole interior, body, new rad support, fromt bumper, doors, rear bumper, hood, etc. etc. etc. So I got LOTS of work to do lol haha
RE: Wishlist
Just to add my $0.02....
I'm not sure I'd go with 3.55 gears. I would chose between 3.73 or 4.10. 3.55 just doesn't seem worth it... but that's just me. I'm already wondering if I should have went to 4.10 over my 3.73.
