Best Way To Spend 2K
Old 07-30-2013, 08:26 PM
PlayinWithTraffic
PlayinWithTraffic's Avatar
Default Best Way To Spend 2K
What's up guys. I'm new to the forums and the Mustang world. I just picked up a 1991 GT that is pretty much stock which the exception of shorty headers and Flowmaster cat back. I'm trying to decide what the best way to spend my first 2 grand would be. Option 1 is a BBK cai, BBK 65mm throttle body, Trickflow upper and lower intakes, an SCT tuner and 3.73 gears (up from 2.73). Option 2 is 170 mm Trickflow Twisted Wedge heads, TF stage 1 cam and 1.6 Roller rocker arms. I want to leave the lower end stock and N/A. Any advice would be greatly appreciated.
PlayinWithTraffic is offline
Old 07-30-2013, 09:13 PM
Duncan_GT
Duncan_GT's Avatar
Option 2.
Its 170cc, not mm
Duncan_GT is offline
Old 07-30-2013, 09:25 PM
reldla1996
reldla1996's Avatar
I'd modify option 2 slightly to skip the cam, add 1.7 rockers versus the 1.6, and use the cam savings to buy a TB and MA sensor. Your fuel pump is going to be on the edge. Once you add an intake, you'll also need 24# injectors. IMO, the cai intake is not going to help much (the factory system is a cai), and the tuner even less so (OBD I cars don't require a tune in most cases).
reldla1996 is offline
Old 07-30-2013, 10:45 PM
tinman
tinman's Avatar
In any case get the gears and some shocks/struts.......
tinman is offline
Old 07-31-2013, 12:01 AM
PlayinWithTraffic
Why skip on the cam? If I don't do the cam do I still need the 6.7" pushrods? I will be getting a TFS Street Burner manifold shortly after, so what size TB and MAF should I run. I'm new to this and I'm trying to get everything figured out before I start buying parts now that I will end up replacing in the future because they don't "mesh" well with other parts.
Old 07-31-2013, 03:13 AM
bluebeastsrt
bluebeastsrt's Avatar
I'm going with option 3- hookers & beer.
bluebeastsrt is offline
Old 07-31-2013, 07:28 AM
Duncan_GT
Duncan_GT's Avatar
Old 07-31-2013, 07:33 AM
Duncan_GT
Duncan_GT's Avatar
With machining tolerances, you need to measure for pushrod length, every engine is different. I have the R manifold, what size is the opening on the Streetburner? You dont want your throttle body to be bigger than that opening. I wouldnt go any bigger than 70mm pending you stay with 302 inches, 72mm on the maf. The only real difference you'll see IMO will be throttle response
Old 07-31-2013, 08:05 AM
PlayinWithTraffic
The opening on the Streetburner is 75mm, but I was planning on 65-70mm for the throttle body. I do plan on staying at 302 and if a supercharger is in the future it is WAY into the future. I thought i had to get a MAF that was calibrated to the injectors, shouldn't I wait until I do the fuel system before getting a MAF?
Old 07-31-2013, 09:12 AM
Duncan_GT
Duncan_GT's Avatar
Yeah you'll need to have it calibrated. Your tuner will be able to do that. I dont know the power limits of the stock fuel pump, so I dont know when is a good time to upgrade. Most guys just go w a 255 walbro and a fuel pressure regulator
Quick Reply: Best Way To Spend 2K
