5.0 A/C woes
5.0 A/C woes
I need some A/C advice from any experienced Mustanger. My A/C clutch needs replacing and I have never done one before. If anyone could giveme any advice with that, holler. Next and last, I am not getting any air through my dash vents. It come through the defrost and the floor vents.Again, if you can provide me with info, please do. Peace.
RE: 5.0 A/C woes
Can't help with the clutch, but if your not getting air out the vents in the dash check the vac lines from the selector, one or more may be lose from the diaphrams they activate to redirect the air flow or worse case which I have run across before is the fitting that all the lines tie into that attaches to the selector on your dash has broken lose or is cracked.
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
