My car is MAD @ me
My car is MAD @ me
How many temp sensors do my 93 GT Stang have cause i found another what looks to be a temp sensor in the intake. (T or F)
The reason I ask this scroll down
[IMG]local://upfiles/70686/F7BDEC2229D74BC5988CF055F949FB68.jpg[/IMG]
[IMG]local://upfiles/70686/F2AB30D7E2674EA184E767FCFAC71E09.jpg[/IMG]
RE: Temp Sensor(s)
you have 3. One is your ACT in your intake runner, the other 2 are in coolant. One in the heater hard lines is your ECT for your computer and the other in your intake (one wire) is for your gauge.
RE: Temp Sensor(s)
The ACT(air charge temp sensor) is in runner #5 in the lower intake
The ECT(engine cooltant temp sensor) is in the heater hard lines
The temp gauge sending unit is in the lower intake, driverside, one wire.
What is wrong? Run your codes, that will tell you if the sensors are good.
RE: Temp Sensor(s)
ok my problem is when the car reaches operation temp it startsto act like it's surging or missfiring (only when warm). It's doing it at idle &accelerating it just came out the blue ok i've took it to two Shops the last shop said it's itermediate or something like that. I've changed the 02 sensors, Coolant sensor, Air charge sensor almost forgot, wires, plugs, cap & rotor, ignition module, & coil.
I'm taking all suggestions,thanx for listening well reading
RE: Temp Sensor(s)
I've put a new COIL on while the car was acting up but it kept acting the same way. I did change t6he ignition module but i didn't put that grease behide it so i'm bout to try that, THANX
