videos from saturday nights heads up races
#51
RE: videos from saturday nights heads up races
it almost sounds like something hitting the valve covers, havent had any of these problems till i messed w/ the timing.i rev'd it up once and the engine just sounds real bad and gets louder w/ rpms, its hard to describe from my memory this morning, but when i rev'd it i guess like 3k or close to it i heard a real loud knock/thump come from inside the engine, alomost sounded like it was in the pan, but i doubt anything did hit it since it wasnt quite loud enough for that.
#52
you prolly just heard your first detonation due to the timing being way off. did you stab the dizzy back in correctly cause you might have it turned 180* out.
#53
i didnt pull it out, i turned it once or twice too far but turned it back and got the timing set, and the dizzy is positioned right where i had it before.
#55
it doesnt matter if its tdc when ur setting the timing right?
i already had tdc on #1 set when we put the dizzy in the first time using a spark plug hole checking for compression to tell TDC.
i dont think the dizzy is 180 off since the plug wires arent long enough for it to spin that far
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
mungodrums
Suspension
09-07-2015 07:28 PM
mungodrums
Suspension
09-07-2015 07:22 PM
09-01-2015 08:16 PM
