converted fuel injected 5.0 to carb having problems
07-13-2007, 05:50 PM
RE: converted fuel injected 5.0 to carb having problems
it does have fuel in and out i have fuel pump line going in and carb line going out
07-13-2007, 05:51 PM
if i unplug line from regulator fuel does squirt out
07-13-2007, 05:55 PM
sounds like you have a bad regulator or it isn't hooked up right.
07-13-2007, 05:56 PM
how do i make sure i have bad regulator?
07-13-2007, 06:03 PM
Quote:
ORIGINAL: fred25mustang
Iwould make sure it is hooked up correctly, then if it still dosen't work, my guess is it would be bad.
Turn the adjuster in, that will open it up, turning out will close it.
07-13-2007, 06:04 PM
alright ill recheck my connections if their ok ill get another one thanks
07-13-2007, 06:21 PM
Good luck.
What kind are you using?
07-13-2007, 11:01 PM
holley 2 port bypass style
ShaneB26154
35
03-04-2021 04:05 AM
dochawk
08-25-2015 08:25 AM
1st 4 eyed fox
08-24-2015 06:56 PM
kdryan
08-21-2015 04:01 PM
MusBBad95
08-17-2015 09:39 PM
1967 ,
50 ,
67 ,
carb ,
carburated ,
carburetor ,
conversion ,
convert ,
fuel ,
injected ,
mustang ,
pressure ,
regulator
