1/4 mile estimate?
RE: 1/4 mile estimate?
87-93 had E7 heads stock
and 86 has the crown for the worst 302 heads ever [8D][&o]
Which head is the best depends on your ultimate goals for the car, the best head for a N/A engine is different then one for a F/I engine
Specs on the cam look pretty mild and with E7's I would expect you to be in the 200-220 rear wheel region...expecting more will be a let down. Upgraded springs and rockers will prevent valve float but the heads will restrict the advantages offered by the upgraded cam to a large degree. The overbore of .020 nets you aprox 0 gain over the standard 302. My guess would be high 14's in the mid 90's. Watch the 'large exhaust' you really don't want to go too large or again you'll hurt performance.
ORIGINAL: SoDakStang
14's is a guess without knowing what your hp is. Stock heads are a huge downfall. Completely stock mustangs should run high 14 so maybe in teh mid to lower 14's. Best guess.
i was looking up all the specs on the ford web sites and mustang web sites and the e5 and e6 were worse and thethen there wer the e7 n one other head which was better then the e7 but yet still the sencond best heads ford made that year for the 302sand the stock cam was a .344 or .244 somthing liek that
