got some stuff done on the 5.0 swap (finally)
well, today was a bit of a productive day[8D] got my poly motormounts hooked up to the block, they look pretty sweet, got them on there nice and tight, not going anywhere, had to run a washer under the bolt, but its good. (thanks My77, you were right on the money with the bolts, they fit perfectly)
also, got the pilot bearing out, finally. Advance first loaned me a bent bearing puller, but I got one that wasnt fubared and got it out in all of 10 minutes...
just gotta torque down the flexplate bolts, 67 ft.lbs is what the box said...
also mocked up my 4pt K-member brace, but gonna wait till the motor is in to put it in, otherwise getting the block in will be a PITA....
