NOS With cast pistons?
RE: NOS With cast pistons?
You don't need a fogger, it would be overkill for you. A nice basic wet kit will work fine but make sure you get a window switch and a fuel pressure saftey switch. Keep it at or below 100 hp and pull a few degrees of timing out and run a colder plug and you will be fine.
JD, Why do you say a fogger would be over kill? I am thinking abiut getting a kit myself. On my other mustangs I had they all ran excellent with a fogger.
Also, That Camaro is pretty sweet looking.
You can use a fogger, but it's more money than you need to spend. They are usually for really big amounts. Although fuel distribution is better with them, but at the power you are going to use it's not needed. And thanks for the compliment, I need to update my sig pic.
uberstang1
09-20-2015 06:42 PM
