Anyone with a procharger, Engine Bay.....
I got my motor just about assembled on the stand.. Its mean as hell looking with the 12 rib procharegr setup.. cant wait to get it in the car.. but I think ill have to cut some of my inner panel out were the battery use to sit... Can i see some differnt pics of your guys ebgine bays? ill get pics of my motor asap today..I had to do some trimming on my dam 350doller water pump.. the crank pulley is just a centimeter away from the water pump... But the tensioner should keep the belt down away from rubbing it... also made a bracket for the ac pump hopfully it all turns out good... Would it look ok to cut out like were the battery box n all is? anyone got pics of someone doing this? thanks guys,
RE: Anyone with a procharger, Engine Bay.....
You should have seen it before I altered the intake and put the custom one in there. It's not quite complete yet. I need to cut a hole leading into teh fenderwell area. Then I'm going to leave the filter in the engine bay, but box it off so that it is isolated from the rest of the engine bay. That will force it to pull cooler air in from the fenderwell.
Here's what it looked like before:
When I say that I'm gonig to "box it off" I mean making a custon encloseure so that it's similar to these:
OK, Now I'm confused. If this engine is completely together already? Why are you gonig to abandon it and go with a completely different setup using parts from this one?
