Didnt know where to post..question about power
I'm in the process of looking at a 95 gt that is heavily modded and im wondering what #'s it should put out?? Here are the mods
Rebuilt E7e heads w/ new valves, stems, seals, comp cam springs, keepers and gaskets
- Cobra upper and lower intake w/ 2 inch spacer
- Holley powerseries 70mm TB
- Cold air w/ 75mm Pro M mass air relocated to inside fender
- Ford racing #24 injectors, ford racing 1.7 rockers, ford racing roller lifters and Comp cam valve springs
- Ford motorsport E303 cam
- BBK shortie headers and MAC x pipe no cats
- MAC flow tubes welded to flowmaster 40 dump mufflers
- MSD 6AL box, MSD coil and MSD cap and rotor
- Taylor 9mm wires
- caster camber plates
- New dubble roller timing chain
- New harmonic balancer
- Alum driveshaft
- Alum radiator
- 3.73 gears and posi
- Rebuilt T5 w/ hardened shafts, sycros, springs, shims and solid 2nd gear blocker
- Centerforce dual friction clutch and new flywheel
- Steeda Tr Ax short shifter
- Energy susp poli bushings upper and lower arms
- Pro M PIH harness for fan control system
jw about hp/tq and estimated qt mile times
- Taylor 9mm wires
- Alum driveshaft
- Alum radiator
RE: Didnt know where to post..question about power
Being that it's a 95 this should be in the 5.0 tech section. But I'll throw a number down anyway. I guess 240ish HP and 280ish TQ Without a set of heads those mods aren't helping a lot, the anemic heads won't allow the engine to breath as well as the mod list should allow.
not even close to 300 on e7 heads, about the most you can get out of them even heavly worked is around 250 rwhp NA
swap heads on that car and you could have a real power house though
KingRando
10-02-2015 08:06 AM
09-25-2015 06:58 PM
