Hourse Power guess
Hourse Power guess
OK, here it is...For all of you pony experts, I will list the following and give me your best educated, non educated guess.
Ford crate 302 5.0 347 stroker kit:
Edelbrock Victor intake
Edelbrock 70 MM Throttle body
Granatelli Air reg set to 39 psi
24 Lb injectors
190 Walbro fuel pump
MAD AL6
BBK = Shorttys
Smog delete
Underdrive pullys
GT 40 Iron heads
Next guess 1/4 mile
M/T ET street radials
Upper & Lower control arms
Full lenght welded in subs
Camber Casters
Skinneys
Battery in trunk
Line lock
Picture taken before battery re locate
[align=left] [/align]
24 Lb injectors
MAD AL6
BBK = Shorttys
Smog delete
Underdrive pullys
GT 40 Iron heads
Next guess 1/4 mile
Camber Casters
Skinneys
Battery in trunk
Line lock
RE: Hourse Power guess
you don't list gear ratio or trans , so i'm going to assume 5-speed w/ 3.73 and it is a 'vert , mine was 3450 w/ no driver and 1/2 tank
13.40 @ 101 mph
potential ????? as quick as 13.10-13.20 but i'm not sure if i see more, maybe who knows
13.40 @ 101 mph
Thanks for the input....I ran, a 13.50, 13.96 & a 12.80 I'm pleased...After it is all motor. With a 100 shot or so 11.00's and a roll bar.
Thanks you all
Thanks you all
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
logan409
09-26-2015 07:43 PM
09-25-2015 06:58 PM
