turn signals
RE: turn signals
ORIGINAL: mattdel
nah, different circuit. check the flasher relay?
RE: turn signals
ORIGINAL: mattdel
RE: turn signals
ORIGINAL: 5.0stanger
Wrong, it runs thru there. I broke a wire loose inthe switch whenI had my dash out and my signals wouldn't work...hooked the wire back up and it worked. You have to have the hazard switch in place for the signals to work.
ORIGINAL: mattdel
RE: turn signals
Well I know that one of my flashers, the turn signal flasher was bad and I swapped it with the hazzards and the turn signals worked, but no more hazards....
A dead battery is not going to allow your turn signals to work at all. Time for a 3G upgrade.
My flashers are under the dash near the steering wheel.
RE: turn signals
With a bad flasher, you signals will come one, but wont flash right? Without the hazard in, you wont get anything. What was funny is my hazards worked, but the turnsiganls did...just because of one wire.
