ratling from driver back wheel
well I hear a metal tang , linda like when you drop a oven pan on ground when i get higher gear/bumbs uneven road. My brother took my car down to his work to get my E-brake cables put in. In the tunnel he said the noise when away when the brakes were applied. I thought was spare tire not being bolted down but not im not sure. If I take wheel off what should I look for? any suggestions appreciated.
RE: ratling from driver back wheel
when i bought my 89 notch a few years back i kept hearing a rattle coming from the rear when i hit bumps and it ended up being loose drive shaft bolts. not sure if it helps but worth a shot.
