Inspection= Headache
Old 08-10-2007, 11:25 AM
Black95MustangGT
Black95MustangGT's Avatar
Default Inspection= Headache
I was supposed to get it at the end of july but i didnt have enough money to get the stuff fixed that would fail. So i finally fix it yesterday, go out today and try getting it inspected and what happens? The switch to the wiper blade just doesn't want to work. It will work when you use it to clean the windshield, but if you want it to stay on continiuosly it won't. It's so lame how you can fail over the most stupidest ****, atleast they still work.
I can't replace JUST the switch, i need to replace the whole part that goes into the steering column. 40 dollar peice, and i dont know if this is true or not but my friend at work said they are reaaaal hard to put in and im better off letting a shop do it..which could cost a good 500 he said..
Is that true or not? Because it doesn't really seem true.
Black95MustangGT is offline
Old 08-10-2007, 03:36 PM
stang8689
stang8689's Avatar
Default RE: Inspection= Headache
Damn that sucks I hate inspection, I don't think its that hard to do, but then again I have a 86 with no air bags
stang8689 is offline
Old 08-10-2007, 04:27 PM
mattdel
mattdel's Avatar
its a breeze.
take off the plastic shroud covering the bottom of the column, and you should see 2 or 3 screws that hold it in place.
easy as pie.
mattdel is offline
baddog671
07-26-2016 01:20 PM
JonnyBlazeGT
11-03-2015 01:10 AM
04stangman
09-26-2015 09:33 AM
prophotog
09-15-2015 08:38 AM
Insidian
Carolina Regional Chapter
09-08-2015 05:33 AM
Quick Reply: Inspection= Headache
