What Color?
RE: What Color?
ORIGINAL: Jasperstang308
i would keep it red. cheaper. if you change the color are you going to haev the engine bay painted? the jams? the trunk? if you change the color the price is going to SHOOT UP
buy an air compressor, spray gun, psi regulator, paint.....total around 600 for tools. paint would run about 300-400 in total supplies (laquer based paints) so you could have your car painted for about 900-1200 bucks depends on decent good and have a pretty sick paint job.
worst case at least prep and prime yoruself, save yourself some money when you can.....your cant really Fug up primer.
RE: What Color?
ORIGINAL: FivePointOhh
[paint it yourself.
[paint it yourself.
everything thats bolded is wrong. for the sake of money and trouble, just get it done if you havent done one before
RE: What Color?
ORIGINAL: jakeachy
ignore that whole post.
[paint it yourself.
[paint it yourself.
all you had to say, "it wont be fancy...but its works" and thats the truth!
RE: What Color?
Again, if you're inexperienced, stick with solid colors, and leave the metallics and pearls for the more experienced. Solid colors are more forgiving, both during the spray process and afterwards when it comes time to sand and buff. Plus, they're generally cheaper.
The primer flashes in 5-8 minutes between coats and can be topcoated in one hour. If you are going to let the primer sit for more than one hour and you are adding extra coats of primer, you will have to sand the primer with 600-grit paper. The shortcut is to not let it dry for more than one hour between primer coats. You don't have to sand before the topcoat is applied, it will just add scratch marks to the finish. (you may be right on the primer but i would never let mine sit for more than couple days.)
Supplies
Description
Price
3/4-inch masking tape
$1.75
3M 320-grit wet or dry sandpaper, 100 pack
35.29
Acetone
8.84
DuPont V-4904S primer/filler, 1 gal.
123.00
DuPont V-4975S activator, 1 qt.
61.00
Nason basecoat, 1/2 gal.
40.00
Nason activator, 1 qt.
28.40
DuPont HC2300S clear, 1 gal.
151.79
DuPont HC2305S activator, 1 qt.
47.69
Inline air filter
47.00
Overspray sheeting
27.63
Respirator
17.67
Sharpe air regulator
27.00
Evercoat brushable seam sealer, 1 qt.
14.37
SEM self-etching primer, 1 can
11.03
Quart pails, 6
2.94
Total:
$645.40
you can look up DIY painting all around and they'll pretty much all say the same thing. so right now i'm pretty confident on what i've been taught in school and what i've done. you show me something different thats not proffesional grade because, we're not pros at painting our cars.
http://www.carcraft.com/techarticles/ccrp_0612_amc_rambler_body_repair_paint/index.html
Supplies
Description
Price
$1.75
35.29
Acetone
8.84
123.00
61.00
40.00
28.40
151.79
47.69
Inline air filter
47.00
Overspray sheeting
27.63
Respirator
17.67
27.00
14.37
11.03
Quart pails, 6
2.94
Total:
$645.40
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
