power to manual windows
my windows need a bit of a overall and i was thinking of maybe going oldschool with the crank windows and no power locks. it will kinda fit the whole theme of the car i think. my question is what do i need to get this done. do i just need a window crank and the regulator thing plus a rivet gun or is there alot more do it then that. also, where can i get some oldschool armrest that don't have the power stuff on them. will pre 87 ones fit in my car fine?
RE: power to manual windows
Pretty easy, you need the manual regualtor, 1/4" rivets and a big daddy rivet gun. The rivet guns are only $20 for a cheapo. I think I have some if interested and will include new rivets, p.m if interested
ORIGINAL: adumb
ORIGINAL: stang8689
also how the heck are you sapost to get this big daddy rivet gun in the door and have room to work. i honestly have never used a rivet gun so is it just a point shoot thing or is it a total pita
post up some pics of those door panels and are rest and well see. are they greay cause that is what i am looking for.bb
ORIGINAL: adumb
are you sure the panels are different for power and non power cause 50resto doesn't list different ones for each.
First, top is the dark gray panel from my 87, bottom is a lighter gray GT panel note the length of the opening for the arm rest and even though the GT is missing the insert you can see a power window panel has a longer insert that is what screwed me up I was wanting to use my old inserts.
Next power panel with arm rest set in place
Non-power arm rest on power panel.
Back side of arm rest both are E7 (87) pieces note the location of the t-shaped metal alignment hooks.
Sorry but I don't have the blanks for my old arm rest that would go where the door lock switches are.
And final top view.
As you can see I have a set of GT panels but they are missing the inserts and I hate the door pockets I was going to put carpet on them and re-paint them like my LX panels.
But since my old inserts won't work I was going look for a different set of panels.
I need to get the proper wireing harness for the driver door too.
zanemoseley
09-06-2015 12:58 PM
