whats your thoughts...?
RE: whats your thoughts...?
edelbrock rpm II is a good choice and as far as cams go too many opinions out there from get a custom grind to out of the box bolt on one....I believe if you just want a out of the box one comp cams has a line designed for strokers I think it might be the XFI line???
As far as the cam goes, if your not going with a custom, just call up Comp,Crane or any of them and ask them for advise. They will LIMITED knowledge of what might work best for you. If you have no idea and are not going custom they might can pick one off the shelf better than you.
