just a worthless hp guess
i am looking for a hp guess on this setup...
-it dont matter but its in a 91 mustang coupe
306 (original 302 block)
9:01 compression
flat tappet
351 heads
shortie bbk headers
homejob ported stock 5.0 ho intake
bbk fuel regulator
255 lph bbk fuel pump
1 inch intake spacer
1.6 roller rockers
k&n filter
bbk pro billet distributor
....these are parts that came on the car when bought....
professional products throttle body (dont know exact size)
some kind of aftermarket maf sensor
9:01 compression
flat tappet
351 heads
shortie bbk headers
bbk fuel regulator
1.6 roller rockers
k&n filter
RE: just a worthless hp guess
I see. When you said original 302 block i was assuming you meant original for the car because i also was assuming everyone would know that a 306 is a 302 block bored .030 over.
ORIGINAL: vtecwho
not a whole lot more than stock unless you cam it. on a good day your 3 extra cubes will only add MAYBE 4 HP
with what you have listed 205HP
My guess would also be between 240-250 at sea level.
lincolnshibuya
12-08-2015 04:37 PM
BeatnikFink
10-01-2015 08:00 PM
