PAXTON VR4 UPGRADE SN 89 92 93 2000 NOVI GSS 11-16 PSI
Are you tired of getting only 6-8 PSI out of your SN 89, 92 , 93, 2000 or Novi GSS? Then have we got an UPGRADE for you.You are looking at a SPECIAL Paxton VR4 Kit. This will make your head unit push 11-16+ PSI safely and more depending on thepulleys you run.This kit can be added to ALL PAXTON SN model (SN 89, 92, 93, 2000 and NOVI GSS) Head Units.
This kit will consist of:
[ul][*]NEW SPECIAL VR4 IMPELLER[*]NEW VR4REAR CASING (To fit BIGGER impeller)[*]NEW VR4 BELLEVUE WASHER[*]NEW VR4 RACE PLATE* (Only used in SN 89, 92 & 93)[/ul]
We are in the process of have these made, we will only produce 20 of these kits so jump on them while you can. It is a first come first serve basis. Once paid your name will go on the list and once they are finish they will be sent out to you. It will be 4-6 weeks before the kits are completed. If you want the kit installed on your head unit and setup correctly you can send the head unit in to get it installed, for us to install these kit it will cost $100 more, plus shipping back to you. If you want to get the head unit completely rebuilt at the same time we a running a special for $650 (Includes all new internal parts and VR4 kit installed, this does not include the VR4 kit). Please feel free to contact us with any questions @ 281-636-7142.
THE PRICE OF THIS KIT IS $700
*Note: It is REQUIRED that you run an OIL COOLER with this VR4 kit, if you do not have one we sell them for $245 shipped.
Check out our websitewww.cundnracing.comFor All Your Perfromance Needs or give us a call @ 281-636-7142. We carry MAC, PAXTON, C&L, FORD MOTORSPORT, PRO-5.0, SPEC AND MUCH MORE!
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
