larger injectors
Old 08-27-2007, 08:44 PM
gurn
gurn's Avatar
Default larger injectors
hey im lookin to get 24lb injectors for my 94 gt. im also planning on edlebrock intake and throtle body.obviously you need a recalibrated mafs. am i missing anything else, as far as safety to the motor, im not too familiar with the right combinations. can the stock ignition support that? thanks for your help
gurn is offline
Old 08-27-2007, 09:01 PM
samseed101
samseed101's Avatar
Default RE: larger injectors
What mods are you installing that need the 24#ers? If you're only putting the basics (exhaust and CAI) on there as well as the intake, then you don't need them... waste of money. If you do need then and end up getting them, then yes you just need the injectors plus a MAF, unless you get a tune. If you get a tune you'll only need the injectors. And yes the stock ignition can support it.
samseed101 is offline
Old 08-27-2007, 09:33 PM
stang8689
stang8689's Avatar
Just need the maf
stang8689 is offline
Old 08-28-2007, 07:19 AM
luckythirteen13
luckythirteen13's Avatar
unless you have heads and a cam to go with that intake, you dont need 24's
luckythirteen13 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
MacSerio
09-27-2015 01:05 PM
mltdwn12
09-23-2015 08:54 AM
Quick Reply: larger injectors
