Need an ac compressor
I just found out the clutch is taking a ****. I figured I would see if anybody had onelaying around. I figured it would be just as easy to get the complete unit instead of just the clutch. Let me know, thanks.... I am looking in the classifieds as well.
RE: Need an ac compressor
mine just crapped out today too. i took the clutch off
somehow it got tweaked, as if someone hit it with a hammer
i bought a delete kit and once its installed, u can have my old compressor. it is basicaly brand new but will need a clutch
I have one, but honestly you would be much further ahead to just put a new(or used)clutch on it. If you put the whole deal on then you would have to open your system up, thus loosing all refrigerant. To have the system evacuated and then refilled with new refrigerant would be fairly expensive and a waste of time and money, especially if it already works good.
It actually leaks at every spring lock fitting and the low side r134 fitting that comes off the compressor, I have tried 4 fittings as well, I knew I would have to redue the orings and I figured I would do all of it at the same time. I do agree with you, If I had no leaks, I would just put a new clutch assemble on it.
ORIGINAL: 93 LX FiveO
HIS S-197
08-10-2015 05:47 PM
