Bolt-on 5.0 1/4 miles times?
I am curious to what other 5.0's are running in the 1/4 with only bolt-ons?
More speically I would like to know what the quickest SN95's can do with strictlty bolt-ons. Any peresonal experienecs/examples would be appreciated. |
RE: Bolt-on 5.0 1/4 miles times?
Depends on what you consider bolt ons......
i run a full bbk o/r exhaust
65mm throttle body 75mm mass air meter electric fan smog/ac delete 18* timing bbk cai my car does 14.5's all day but should be quicker |
12.1 @ 114.77 ;)Bolt ons only. Motor has never been opened. Stock block, heads and cam.
Thats kind of what I was getting at Pro........technically a supercharger is a 'bolt-on':D
ORIGINAL: 93 LX FiveO i run a full bbk o/r exhaust 65mm throttle body 75mm mass air meter electric fan smog/ac delete 18* timing bbk cai my car does 14.5's all day but should be quicker How did the 65mm work for you? Worth it? |
ORIGINAL: QatarStang Thats kind of what I was getting at Pro........technically a supercharger is a 'bolt-on':D |
13.40 at 104 not spraying 4th...
all my mods bolted on |
Im not sure what you consider bolt ons???is a h/c/i a bolt on????
Ive never taken the motor out of the car I still have smog pump and ice cold ac I have done a H/C/I change I consider this a bolt on cuss I still left the motor in the car. 12.26 my list.......................... 1994 mustang GT 70mm throttlebody bbk 255lp pump in tank kirban adj fuel pressure reg. cheap ebay $18 CAI edelbrock performer 5.0 intake(blocked heat passage into upper intake) gt40p heads with stage 1 port work gt40p headers bassani highflow cat x pipe mufflers cut off strait pipe to the back(other owner did this not me!) cam 4.99intake 5.10exhuast @050 duration 221intake 225exhaust 1.6 roller rockers 5speed manual transmission(cobra clutch) underdrive pulleys shorty headers 3.73 gears(grinding like crazy need new gears) adjustable upper control arms umi lift lower control arms steeda lowering springs epec tuner 125 shot dry nitrous kit $250 dollar cheapo ebay kit(zex tps switch) mt drag radials 315/35/17 on 10 1/2 black chrome torque thrust rims |
ORIGINAL: QatarStang Depends on what you consider bolt ons...... my '89 notch went 13.20's NA and 12.50's and the valve covers were never off the car t5, 4.10's, et streets, smog and ac delete, cai, southsides, mac long tubes, flow cat back, bagged right side, 75 shot NOS dry kit those are all boltons on a 100% stock long block, stock fuel system |
