head gasket replacement, pics
Old 09-24-2007, 02:26 PM
86GT 93LX
86GT 93LX's Avatar
Default head gasket replacement, pics
ok well im doing the head gasket on the gt today. heres my progress so far.
one head left to take off and then clean up everything. the gasket didnt look bad on the drivers side
which is the one that i think was bad. akthough as soon as i started pulleing head bolts coolant was leaking
from the head. one valve looked differant from the rest, but nothing major like i expected
so i dont know.looking at the flat tops and the heads it doesnt look bad for 227k, all my valves are pretty damn clean! i also dont see why regular heads wont work on this motor. and the ports are fairly large too, it seems like this head would flow good but i geuss they dont.
well heres pics
86GT 93LX is offline
Old 09-24-2007, 02:30 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
Default RE: head gasket replacement, pics
hey will you do me a huge favor, i made a post in general but will you put your plenum on your lower intake and measure how tall it is from the base to the highest part of the plenum if you could plz.
FivePointOhh is offline
Old 09-24-2007, 02:36 PM
86GT 93LX
86GT 93LX's Avatar
just a hair under 10"
ORIGINAL: FivePointOhh
Old 09-24-2007, 02:56 PM
FivePointOhh
in limbo
thanks a ton! i might be able to get the new intake in along with the spacer.... sweet it will be close though. the new intake with spacer is a total of 1 foot 1/8 inch with gaskets lol it'll be damn close
Old 09-24-2007, 02:59 PM
86GT 93LX
86GT 93LX's Avatar
cool what intake is it? remember if its too close when u floor it the motor moves and will push on the hood. u might have to get cowl hood
Old 09-24-2007, 03:00 PM
86GT 93LX
86GT 93LX's Avatar
or get a junkyard one and cut a square in it,lol, thats what i did when i had the 351
Old 09-24-2007, 03:20 PM
FivePointOhh
in limbo
ORIGINAL: 86GT 93LX
yea i know, luckythirteen13 had this issue with his typhoon which is what i have. when he floored it it tapped the hood. what im going to do for a temp cowl is remove the skin off the stock hood keep the bracing(modified of course to make room) then fiberglass a new skin on the bracing. i already started fiberglassing a new decklid. so far so good!
Old 09-24-2007, 05:12 PM
86GT 93LX
86GT 93LX's Avatar
now i just gotta get everything super clean and try to clean off everything else i can reach. wondering if my car will run funny if i get rid of the smog stuff. it was in my way so i removed it
Old 09-24-2007, 05:16 PM
aode08
aode08's Avatar
is that the real date on that oil filter?
aode08 is offline
Old 09-24-2007, 06:17 PM
NYMustang50
NYMustang50's Avatar
I hope not.. Also how does the cylinder walls feel are they smooth or beat up???
NYMustang50 is offline
Quick Reply: head gasket replacement, pics
