firing order
RE: firing order
ORIGINAL: HaV
the injector wiring should be easy to tell.. just straghten it out.. they should fall in order.
hope that helps
hope that helps
RE: firing order
Where that pic shows #3 at, needs to be number one, where it shows #1 at is where # 8 should be.. etc, etc.... its just off one position... doesnt matter where you start putting the wires on at as long as they all go to the correct places.
RE: firing order
ORIGINAL: ERock88
yes i understand that, but on my distributor cap itself it shows a number one, do i still do what you are saying?
This is taken from the 89 Ford Shop Manual, and how mine was wired from the factory.
bradleyb
11-27-2015 07:50 PM
1995, 383, 50, 66, cap, carburetor, counterclockwise, distributor, firing, hei, mustang, numbering, order, stroker, wrong
