Emissions in PA
RE: Emissions in PA
ORIGINAL: F250sd
It's not that simple. The car is still not allowed to pass the saftey inspection without the cats either. I know, I am a licensed PA inspection and Emission inspector. The only way to get it to pass would be if you a buddies with someone who will close their eyes.
ORIGINAL: Importssuk
go to an auto auction in your area and buy yourself a beater car for $500. if you put 5000 miles or less on the car between inspections, you're emissions exempt in pa and you can run straight pipes if you want. or, if you wanna be really sneaky about it, you can remove the speedo gear from the trans and your odometer will stop counting and keep yourself under 5000 miles . you'll have to get used to driving w/o a speedometer though. not that i've ever done this myself [&:]
ORIGINAL: 5.0L RiCE EATER
My car currently has cats on it, any one here from PA and would know if the car would pass emissions if I took them off and just welded straight pipes?
mrappe
09-26-2015 10:16 AM
jpplaw
08-22-2015 09:29 PM
