1994 GT Motor Mount Installation
I figure that i need new motor mounts on my car because there is too much shaking inside the car, I was wondering how hard is it to replace them with new ones. If anyone has pics or website where they show you how to do it , it be great.
RE: 1994 GT Motor Mount Installation
yead unbolt them and place a screw jack with a piece of wood under the oil pan and lift the motor up until you can pull oneside out then do the other side in the same manner....but before you waste your time doing that .....check to see if any part of the engine and or exhaust is resting against the body and if the motor itself shakes at an idle you may have an engine performance issue no motor mount problem.... like maybe a vaccum leak causing a rough run and or misfire causing an engine stumble/rough run.......
