bbk long tube headers
Old 10-18-2007, 10:58 PM
darrinshan89gt
darrinshan89gt's Avatar
Default bbk long tube headers
Hello again. You will prob see a lot of threads from me because I just bought this mustang and its my first project car so naturally lots of question will arise. I have bought BBK long tube headers and they are on the car and sound damn good I may add, but the steering column catches on the header every once in a while mostly when slowing down and turning cause all the cars weight is forward obviously. I have raised the motor up some but it has vibrated back to its original place so I need another fix. If anyone has had this prob please tell me the solution. Thanks.
darrinshan89gt is offline
Old 10-18-2007, 11:02 PM
kilgorq
kilgorq's Avatar
Default RE: bbk long tube headers
Check your engine mounts and your steering rack bushings.
kilgorq is offline
Old 10-19-2007, 12:05 AM
greenstreak9205
greenstreak9205's Avatar
what do you mean that you raised it up but it fell back to its original place?
greenstreak9205 is offline
Old 10-19-2007, 12:08 PM
kweb288
kweb288's Avatar
ORIGINAL: greenstreak9205
haha ya i was wondering the same thing????? how can you raise your engine up with out unbolting the engine mounts?? this sounds like red neck engineering
kweb288 is offline
Old 10-19-2007, 09:15 PM
darrinshan89gt
I did unbolt the motor mounts you dorks and raised the motor then tightened them back up obviously not tight enough because it back to its original position on the mount. Now do you understand.
Old 10-19-2007, 11:12 PM
stang8689
stang8689's Avatar
Get a MM steering shaft
stang8689 is offline
Old 10-20-2007, 03:16 PM
greenstreak9205
yea i get it now, but i just didnt think that doing that would make much of a difference. another trick you can try before you buy parts is to "shim" the motor with some washers. that usually does the trick
Jb145700
08-21-2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
10-22-2015 11:55 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: bbk long tube headers
