ok will i notice any difference with an upgraded fuel pump. i dont think so but not sure. im switching from the orig. 4cyl pump to the 8cyl 190lph.
Only if your stock pump was going bad and your engine was not getting adequate fuel. If it was running fine, then you will not see any performance gains from the fuel pump. You could possibly see SOME performance if you change the fuel pressure around a little, but you need to know what you are doing and what to look for.
