a little help fuel pump replacement
Old 10-22-2007, 11:57 PM
jtmustang
jtmustang's Avatar
Default RE: a little help fuel pump replacement
okay so the wires where u cut them and crimp do they stay in the tank to? or outside the tank thanks
jtmustang is offline
Old 10-22-2007, 11:59 PM
91hatchgt
91hatchgt's Avatar
They are in the tank....
91hatchgt is offline
Old 10-23-2007, 12:02 AM
jtmustang
jtmustang's Avatar
okay it justs seems a little weird to have those in the tank?
but this is why i posted this i just wanted to make sure i wasnt gonna blow something up
Old 10-23-2007, 12:19 AM
cleanfitty
cleanfitty's Avatar
ORIGINAL: jtmustang
Yup, even the factory terminals are exposed inside and submersed in the tank.
Here are some pics
http://cgi.ebay.com/ebaymotors/FUEL-...spagenameZWDVW
(not from a fox, but you get the general idea)
cleanfitty is offline
Old 10-23-2007, 12:24 AM
jtmustang
jtmustang's Avatar
ORIGINAL: cleanfitty
ORIGINAL: jtmustang
Here are some pics
cool thanks guys i just wanted to get everything clarifyed cause no work tomorrow so i was gonna get this job done
Old 10-23-2007, 12:36 AM
cleanfitty
cleanfitty's Avatar
Also, you'll want to be sure your gentle pulling the old assembly out so you don't knock the pick up sock off into the tank... you have to do some tricky manuvering to carefully fish the assembly out.
And on a side note, the aftermarket pumps will only fit the factory ford housing assembly. If the fuel pump assembly has been replaced with an aftermarket one, the new pump won't fit the housing without some creativity.
Old 10-23-2007, 12:41 AM
nacanitihs
nacanitihs's Avatar
gasoline does not conduct electricty.. so dont worry about it. you may have to shorten the wires on the new pump so it fits better. but just make sure the wires are crimped so that the wire is not exposed so it wont create a spark.. when i got mine it came w/ a pre bent fuel hose but i didnt use it cuz the stock one was straight and the bent one wouldnt have fit. so i just re used it
nacanitihs is offline
Old 10-23-2007, 12:52 AM
jtmustang
jtmustang's Avatar
sweet guys now one more thing what about when u get it all hooked up when u turn on does it prime the lines itself or do u have to bleed any air out?
Old 10-23-2007, 02:23 AM
91hatchgt
91hatchgt's Avatar
Nope, just turn the car to the 'on' position and the pump will automatically prime the system. No bleeding..
Old 10-23-2007, 10:09 AM
bighungrymatt
bighungrymatt's Avatar
I had a link that walked you through the fuel pump swap that I used, but I cant find it, I know I have it at work, so I will post it in 30 minutes or so
bighungrymatt is offline
Quick Reply: a little help fuel pump replacement
