maf and control arm question
will the maf from a 87-93 fox work on my 95?
and does anyone know how good the summit rear control arms are? they usually make good parts and for uppers and lowers its only $230. |
RE: maf and control arm question
the fox MAFs were considerably smaller than the SN95 MAFs, not sure if it'll work though. I know the foxes dont have the flange...
well i got a chance to buy a c&l maf with 75mm housing and calibrated for 30lb injectors which ill be getting.
so i need to know if they will work with the computer or if i cant use it. |
It will work with the computer, you will just need to figure out someway to mount an air filter to it....that will be different. The tube from the MAF to the TB wont work either.
i've only heard of goodthings about summit parts too. i have upr control arms. i bought them 5 or6years back can't remember them being too much more. i love my set.
so then what would i need to do to make the maf fit?
just buy the pipe that works with the fox's style? and im sure i could rig something up to make a filter work. |
dont get a C&L maf... please, for the love of god.
your doing a 347 stroker... dont cheap out on your air metering parts... |
i thought c&l was a good brand?
alright if they suck i wont waiste my money. what IS a good brand and since ill have to buy one new which size opening would work best with the 347 matched to a holley intake? |
i believe it could work. however, i think the length and bends are what you will have to overcome. i'm not actual sure haven't try it. being that we have a inlet adaptor and the angle the throttle body sits. other than that it should work.
oh! by the way we have the same color and year car. looks good!!! |
