351 question
i tried the search engine, and i got nothing.... how much power does a H/C/I 351 make? i found a 351 short block pretty cheap and i was just wondering.. also, are any of my mods from the 302 compatable with the 351? thanks
RE: 351 question
351W + AFR 185 + .580 lift stroker cam + 10.5 c/r = 450-500hp flywheel
nothing worth swapping from your 302 |
RE: 351 question
wow i didnt think you would get that much with just bolt ons.... so my rpm 2 intake would not be able to bolt on it? what about my tranny?
RE: 351 question
damn short block is gone[:@].... but this 351 swap has me interested...
RE: 351 question
it depends on the parts you use. a GOOD head cam and intake can make an easy 500hp
RE: 351 question
i want to keep i fuel injected.. thats why i was wondering if my rpm2 intake wold work on it.. afr 185's sound good.. would my computer work ona 351?
RE: 351 question
my rpm2 will not work... only the upperintake wiil work buti have to buy the 351 edel lower then port it to match my upper... trickflow has a 351 intake upper and lower but i dont like trickflow.... there is the spider intake but seems like alittle over kill for a mild set up (like r.barns)..
RE: 351 question
whats wrong with the spyder? i am putting one on my 347. it is bit of a wild set up but for a 351 it would be fine. also whats wrong with trickflow?
RE: 351 question
Nothing wrong with spider.
Get it from Edlebrock for lot cheaper too. |
RE: 351 question
so the spider intakewould not be over kill for H/C.... still learning this stuff:D... i was going to get heads for my 302, but the price for a 351 hci is not much more... so for the swap you need a oil pan, headers, and what else?
