horsepower estimate?
RE: horsepower estimate?
its called drivetrain loss dip****, go cry about it
my rule of thumb ive been taught is you lose a little less than 50 on both through a manual, a littler more with A/T but ive also heard 15 percent
the machs engine dynoed at 400 to the flywheel, dynoed 310 to the rear...
DEAL WITH IT
and im guessing that your engine a little rustier than it once was and thus is not running at full potential, my guess is even with mods your probably making about 220 at most to the flywheel, which is about 160ish at the wheel...
sorry, 170, im being stupid, 170/240 is what i shoulda said, i kindof just threw out a number..
DEAL WITH IT
Well then you need to read my post again. I said that the car might have made 210hp at the flywheel (when it was new) now it probably makes less. You lose quite a bit of HP through the drivetrain, so your car actually made around 170-175hp at the wheels/to the pavement when new. Now that it is 22 years old, it is probably making somewhere in the range of 160-165 to the pavement. Then you threw on WAY TOO BIG of a carb on it, so you are probably losing HP with that, so I would guess you are making 150ish hp at the wheels right now.
Of course, this is coming from someone who has only built about six 5.0 mustangs in my lifetime, so take it or leave it.
oh okay sorry about that!
well im new to this car so i dont know anything except for what the guy i bought it from told me!
that is why i am on here trying to figure out anything i can about my car!!
by the way about how much does a 1985 mustang vert weigh some 4 door ricer was complaing that i only beat him because my car was lighter! i told him the car weighs 2000-3000ibs because of the v8 302!
ORIGINAL: FuzzyDiceRule
ok, 86, help me out, im **** with carbs, but im assuming he would loose power, and or not be using the full 750 cfm to the full extent, am i right?
ORIGINAL: 855.0sean
you really have no clue how much a car weighs do you?
anyway its around 3100-3200lbs
umm, i believe my car iw 2800 lbsish, im assuming yours is in the 2900-3k range, because its a vert, so, if he was in a civic, he was definately lighter...
but even with the huge carb, your probably making a hundred more horsepower...
ORIGINAL: 855.0sean
Stick around for a while, and you will learn all you need to know. First thing's first, ditch that huge carb.
no it was a mitsubishi galant or something any ways ill put the stock carb back on it.would that bring it back up some?
and the race was from a dead stop by 3rd gear i was about 2 1/2-3 car lengths in front of him by 4th he gave up! lol
