Best way to spend 5,000
RE: Best way to spend 5,000
ORIGINAL: irish1
1 pick up 351W shortblock needing rebuilt 100
2 buy 408 stroker kit 1000
3 buy set of afrs 1800
4 add your fav intake500
5 get assembled400
6 get tranny rebuilt 1000
7 buy clutch 200
total 5000 add a few hundred for small stuff like pushrods/hoses/belts/plugs/gaskets you get the idea.
5 get assembled400
7 buy clutch 200
the cheapest 408 kit on fordstrokers is 1499
ORIGINAL: capri debris
Turbocharge the current motor and save up for when it blows up then rebuild it.
I would build the drive train first(like axles, gears, carrier, drive shaft, tranny and clutch, contorl arms, springs) You could do all that for under 3 G's, then take the rest and do a HCI. Just keep in mind all the other supporting mods you will need like fuel pump, MAF, andinjectors. IMO, just a built motor and nothiong else is a waste. I would rather have a well rounded everything so it will work best together.
Luke9222
10-22-2015 11:55 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
