my $200 lx hatch will it run without the o2's hooked up?
#23
RE: my $200 lx hatch will it run without the o2's hooked up?
yeah i will be hookin it up tomorrow tired had to work today but tomorrow morning.
i also noticed the spout connector is unplugged and the other end is gone will this help in runnin like **** or will it just set off the check engine light.
#24
ORIGINAL: AdderMk2
you're a ****ing moron
ORIGINAL: 1fstlx
dude no.................. itll run fine on just straight headers
#27
alright well i put the headers on the mid pipe bolts were rusted so fu#@ it then put the wires,rest of the harness together,retightened the starter, turned the key and it literally fired right up idled fine (somehow with the egr plugged off and the smog pipe from the heads plugged and no o2's) so fired right up i let it idle for like 30 seconds and it was all fine revved it up a little and it wa fine oil pressure went from the bottom 0 up to like almost three quarters which on the stock guage it would be like 60-65 pounds of oil pressure
so i turned it off and did a compression test on it
1-145
2-142
3-141
4-138
5-144
6-143
7-138
8-135 so that was cool to see it did smell like it was runnin a little rich zach but all in all im stoked my 240 5.o runs
1-145
2-142
3-141
4-138
5-144
6-143
7-138
YoungStangsMan
09-05-2015 07:01 PM
