x mas presents??
RE: x mas presents??
ORIGINAL: bansheeyfz
is there a superchip or somthing for theseS?
You wouldve been better off stating whats done to the car already in your original post so we dont suggest stuff you already have.
Wouldn't a 93 have a 55mm MAF? A aftermarket one should yield a modest gain, considering there is a lot of room for improvement.
You really need to list what you have. Check out Summit Racing, and yeah, don't buy a generic chip.
Alright,heres a few ideas:
[ul][*]Sub-Frame connectors,strut tower brace, or control armsas far as suspenion goes.[*]Crane Fireball Igniton kit(Controller w/rev limiter and coil), fresh cap and rotor and FRPP 9mm Wires for the igntion equation.[*]Throttle Body and MAF for the intake side.[*]Royal Purple Fluid in tranny and axel.[*]Brakes would be hard to upgrade for under $300 aside from some slotted rotors and good pads up front.[/ul]
See what 1985stang has to say about the frame connectors.
Whatever you decide on, be sure to research it yourself and make sure its what oyu want.
I would say defenitly do the suspension.. Get upper and lower control arms. They help you launch the car alot better. Then get subframes and the strut tower brace as mentioned above.
ORIGINAL: 94Blk5.0
and you can get them on ebay for $20
Only thing about the SN 70mm MAF I don't like, is the post in the middle of it. Maybethe doesn't really hinder anything, but I replaced mine with a C&L( came in the CAI kit.) I know Adder doesn't trust the C&L's, but it works great on mine. Vortech may also make a 73mm or 76mm housing like C&L's, where you just stick the stock senor back on it.
Would a 19 lbs/hr. MAF withaftermarket electronics require a tune?
