Oil help needed.
RE: Oil help needed.
ORIGINAL: cleanfitty
This is a load of crap... anyone that starts to feed you schit that their engine runs cooler with "Brand X"oil has to pull their head out their ****... Your thermostatmaintains your temp, not your oil.
ORIGINAL: 1985stang
Maybe I'm missing something [&:]
Yes you are... it's like saying, "Wow! with this oil, my engine runs so much cooler now that I never reach full operating temperature"... Or saying some bs like, "the other oil caused so much friction that it caused my engine to run hotter than my cooling system was able to handle"
Ans the fact that his gas milage doubled by using M1...
And that engines are now lasting longer due to better oils... (Yes oilsand lubricants are better nowadays, but it is mostly due to more precise tolerances, better factory balancing, fuel injction, better metals, internal coatings, etc.) You could take a mexican block chevy 350 and use all the M1 you want, andit still wouldn't last more than 75K miles. Put all the M1 in an all aluminum vega engine and your still going to be a smoke machine at 40K miles.
When someones article tries to giveme the business, I turn the other cheek [&:]
ORIGINAL: 1985stang
