TRANNY SWAP
TRANNY SWAP
WHAT KIND OF PROBLEMS WILLI RUN INTO SWITCHING OUT A STICK TO AN AUTOMATIC??A BUDDY OF MINE SAID HE DID IT AND THE CAR WOULD ONLY SHIFTUP TO 2ND GEAR?? HE TOOK IT TO ANOTHER GUY TO HAVE IT SHIFT PROPERLY. DOES THIS SOUND RIGHT. I HAVE A 91 COUPETHAT WAS A STICK AND I'M GONNA PUT AN AUTO IN IT AND WOULD LIKE TO AVOID THIS PROBLEM.THANKS
RE: TRANNY SWAP
ORIGINAL: djh1121
Just wanted to ask why would you want to go from a 5spd to a auto? I'm wanting to change my auto out for a 5spd...
RE: TRANNY SWAP
ORIGINAL: stang8689
probably for drag racing
RE: TRANNY SWAP
ORIGINAL: greenstreak9205
a 247 huh. i woulda put it behind a 347 but thats ur call
RE: TRANNY SWAP
umm wow man calm down there a bit. he was probably just messing with you. its nothing to get all bent out of shape for. this is a GREAT place to get good info if you ask the right people or the right people respond. but as long as you have all the components i.e. stepdown cable and all, you should be ok. i dont know about on the mustangs but i do know in 9/10 cars you need a new radiator for cooling the trans fluid. a manual car does not have the hookup for it on the bottom of the radiator
