jeesh you have one problem with your motor and u just go all out and rebuild the whole thing
lol good choice on the 347 tho! I got mine on order right now.
dont want to fix another 302, so I always upgrade, I didnt just rebuild a t-5 I bought a tko
who says you need to fix anything on it??? carbon build up in an intake is quite normal because the pcv is drawn in through there and I've seen way worse than yours...a good induction clean will solve that problem
mine did the same after a few juuce runs!!! I wasted the 2 front mains!!!! crankshaft flex I believe pinched oil flow off briefly and took out the front two mains..literally I charred one!!!! black as can be ..won't even fit in the cap anymore[:@]
