UPDATE: Im not the next Nieb!!
#21
RE: To avoid being the next MarkNeib...
ORIGINAL: USMC1775
Well he didnt run the engine, supposedly he just poured it thru before re-adding his oil.
ORIGINAL: mjr46
i WOULDN'T RECCOMMEND DOING THAT BUT IF IT WORKED.... IT'S HIS MOTOR...PERSONALLY WE USE a oil flush machine that is hooked up to where the oil filter is in place of it and run a oil flush chemical kit through it while running the engine and it works well
#22
ORIGINAL: mjr46
wrong!!! he hooked the hose to the upper valve cover and removed the drain plug and then started the engine and ran it until clear water came out the drain plug hole...that's what the thread stated according to the OP when he performed the flush cause that's how a member on here told him how to jokingly perform a engine flush..to everyones suprise he did[:@]
ORIGINAL: USMC1775
ORIGINAL: mjr46
#24
Drained his oil out of his new 94 Cobra, hooked up the hose to the oil filler neck, filled engine with water, warmed it up, and drained the water out. Then he added oil and expected the car to still work.
#28
ORIGINAL: bikeboy587
how bad did he hurt the engine? seized?
