HP and E/T Estimates
I am building up a LX 5.0 5 speedwith the following...
Fresh engine rebuild (all gaskets, seals, rings, bearing etc)
Trick Flow Twisted Wedge top end kit (360hp)
Taurus Fan mod
Cold air intake
75mm EGR Plate
75mm Throttle Body
90mm Mass Air Flow
24lbs injectors
MSD 6AL, blaster coil, spark cables n' chit.
Short throw shifter
3.73 gears
MT ET Streets
(suspension is onhold until new year, will order: upper and lower arms, subframe connectors and 90/10, 50/50 lakewood shocks)
Any guesstimates?
Taurus Fan mod
Cold air intake
75mm EGR Plate
75mm Throttle Body
90mm Mass Air Flow
24lbs injectors
Short throw shifter
3.73 gears
MT ET Streets
Any guesstimates?
