what is the max torque that should be run on a stock drivetrain?
Old 12-23-2007, 03:44 PM
we b gpn
we b gpn's Avatar
Default what is the max torque that should be run on a stock drivetrain?
I am sure it is posted here before, but i did a search and cant find it. what is the most HP and torque that can be run on a stock tranny and rear? 5 spd 8.8 on a 87-93 gt? i am looking to get near the 400hp mark at the rear wheels and was wondering when i will need to upgrade the transmission if i need to. if someone has a link to another post that would be great also. thanks
we b gpn is offline
Old 12-23-2007, 06:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: what is the max torque that should be run on a stock drivetrain?
go untill she blows!!!..it really depends on how hard you launch is when most t-5 failures occur
mjr46 is offline
Old 12-23-2007, 08:43 PM
ACE
ACE's Avatar
300 ft lbs...(stock) haha like mjr said depends how hard you launch! I have seen them blow stock but then seen them hold up to 400 ft lbs for a long time when driven correctly
ACE is offline
Old 12-23-2007, 09:13 PM
50fiend
50fiend's Avatar
gotta use the clutch with a t5.
50fiend is offline
Old 12-23-2007, 09:23 PM
hrd2bslw
hrd2bslw's Avatar
I sheard the blocking rings off first gear and exploded both axles out of the housing at Old Diminion raceway two years back with my 88 GT. Stock T5 tranny, stock 8.8 rear with 4.56 gears, 303rwhp/320 rwtq, leaving the line at 7000 rpms on a 26x10.5" Tire.
I would say a stock 5.0 drivetrain will hold-up to roughly 450-500 hp on the street with "street tires" and around 250-300 at the track with slicks. Stock T5s are junk and don't take much abuse. Get a tremec tranny out of the 93-95 cobra's or swap to a 600 series or a G-force version. The rear-end you shouldn't worry about too much unless your going to the track. Then I would suggest upgrading the axels to stronger ones like the factory replacement 28 spline mosers or superior.
Either way GOOD LUCK !
hrd2bslw is offline
YoungStangsMan
09-05-2015 07:01 PM
whatsup62
08-29-2015 01:25 PM
Black_GT_02
08-20-2015 01:26 PM
05slpGT
08-12-2015 02:32 PM
ccwebb
08-11-2015 06:47 PM
Quick Reply: what is the max torque that should be run on a stock drivetrain?
