building a 347 on a stock block?
when I get close to graduating college, I want to build a 347 stroker for my convertible, and back it with a viper spec T56...
(its MY graduatuon present ot myself)
would building a 347 on a stock block be a good idea, or should I invest in a Dart or Boss block? I want to make close to 400hp while keeping it natuarally aspirated, but leave it open for a supercharger., I love that whine
would a supercharger be a good thing on a 347? I dont know much about strokers...
RE: building a 347 on a stock block?
the general rule is do one or the other because a stock block cant handle both.
with my old motor i was going to supercharge it but i was only expecting around 350-360rwhp with boost friendly compression. with a procharger or vortech i was hoping for 500-550rwhp
I'll tell you what Woody at ford strokers told me....quote un quote "If you have to spend 4500.00 plus and buy a boss or dart block to make 400 hp and be okay then the whole ford racing world might as well come to an end"........400 hp and a stock block and you should be okay.....where you'll run into probs is if you try and throw boost on top of that and or a healthy shot of NOS
thanks guys, I know little about strokers other than they increase the stroke etc...
now all the oiling problems Ive heard about with the 347 have been corrected right?
ORIGINAL: Shelty
ya all but one thing with the 347 has been corrected and cant be unless you go with an aftermarket block, the rod geometry is a little off in them and to free up some horse power and gain engine life you bore .40 over i belive it is instead of .30 over and you run slightly less stroke still making a 347 CID motor but putting the correct geometry back into the motor. but unless your trying to make 700+ horse power your fine with the 347, but like everyone esle says anyting with 450-500 and the stock block is a ticking time bomb
yeah, all I want to do is get close to 400 hp, enough power to spank almost anything I run into, but still docile enough to drive on the street without much trouble, hence the 6 speed, that lower final drive ratio would help me with my commuting lol.
but this build wont happen until I am out of college, still would need to score another block, clean it up, get all the kit, the top end etc... the small stuff, like the brackets, P/S A/C, alt etc, would be swapped over, hell maybe even a tubular kmember, and some coil overs, make that thing the ultimate corner carver( which is more fun than drag sometimes IMO. have to wait until I actually make some good money in my future career, get some garage space (my own house) and some more mechanical skill...
ORIGINAL: moocow_v
then you shouldnt need a supercharger, a 10:5 compression 347 should get you up to the 400 horsepower range quite easily with a decent N/A setup
93 or would 87 be fine?
(still learnin)
doesnt a stock 5.0 make a 9:0 or 9:1 compression?
