RE: So I just ordered a set of 4.30's
If you're not making enough power, leave it alone. Plus it depends on how your current set up works for you now.
ORIGINAL: rust_stang ORIGINAL: PRO50SC ORIGINAL: rust_stang ORIGINAL: PRO50SC Yeah, going to a 28" tire. http://www.fordmuscle.com/calculators/rpm.shtml it slows you down because when you put a bigger tire on your car it lowers the rpms you run at (its basically like putting on a smaller gear set) |
ORIGINAL: PRO50SC If you're not making enough power, leave it alone. Plus it depends on how your current set up works for you now. |
Well, it depends on trap speed/rpm. Use the calculator I posted and see where you come in at w/ your current #'s then plug in the new tire size and gear ratio.
Speed (MPH) 104
Gear Ratio* 4.10:1 Tire Diameter 26 ENGINE RPM 5510 Speed(MPH) 104 Gear Ratio* 4.30 Tire Diameter 28 ENGINE RPM 5366 |
How much power are you making, if less than 350, I would stay w/ the 4.10/26. Even w/ the 4.30's, you still gotta have the power to turn over them taller tires.
Here's where I am now
117.97 mph 3.73 26" 5687rpm W/ the new set up 117.97 4.30 28" 6087rpm Pretty much where I wanna be, I hope!!:D |
Hopefully I have 300rwhp. It hasnt seen the strip or dyno yet, pretty much because its winter.. so stick with the 26"/4.10's? I did see one guy at the track with a stock 460 in his fox. ran 13 flat with 28"/4.10's so iunno. Hopefully you get 11's!!!
I have had dealings withthree sets of Motive 4.30s and everyone of them whined. Two sets were in customer cars and one set was in my own. I will never put another set in a street car again. I worked on them until my fingers were bleeding trying to get the tooth pattern so that they wouldn't whine. Shim changes only changed when and how loudthey whined, it didn't stop them from whining. I went to 4.56s and 4.10s, they were no problem. I just can't seem to catch a break with 4.30s. Are you putting them in yourself? Good luck!
ORIGINAL: rust_stang Speed (MPH) 104 Gear Ratio* 4.10:1 Tire Diameter 26 ENGINE RPM 5510 Speed(MPH) 104 Gear Ratio* 4.30 Tire Diameter 28 ENGINE RPM 5366 |
