h/c/i
#21
RE: h/c/i
ok it can be done for close to 900, but try for 1200 or so
if you dont find intake+heads for less then 500 then buy a complete motor from a junkyard for 500, then get a cam... comps are about 250, and im very happy with mine... you could grab an e cam or what not for cheaper
you WILL need new valve springs locks and retainers... you NEED them w. a cam swap, no questions asked.
headbolts, yea stockers dont reuse... get arp.... u can reuse them...
remember i told you, its gonna cost 4-500 to do ur cam
so even at best ur at 900 right now, never mind the 100 for gaskets, 70ish for fluids, and atleast 50 for misc ****, timing chain is 20 bucks...
so shoot for 1200-1500 and its very doable
#22
RE: h/c/i
ORIGINAL: 92cobra
ya and he costs a fortune, im trying to get an h/c/i fully done for 900 bucks. and i think it might be possible now.
Simply because the demand is so High.
#23
RE: h/c/i
ORIGINAL: aode06
Ill tell you all something, Ford Performance will always cost more than Chevy, sometimes 59% more.
ORIGINAL: 92cobra
#24
RE: h/c/i
ORIGINAL: 94gtcobra
What could happen if you use the same head bolts. We did my buddys h/c/i with all the same bolts with no problem.
as far as a budget goes.... good luck. i had to spend 1100 bucks for my CAM swap because of misc. stuff i needed to replace. of course i could have done it the cheap and easy way and not buy the water pump,smog pump,timing chain, radiator, new hoses, belt,pushrods, lifters, and much more. but if i did not buy that stuff i would be replacing it all now. why in the hell do a job twice if you dont have to.
do it right the first time, just save.
PS. im doing my third head swap only im putting on AFRs this time. i know how frustrating it can be to do something like that so this time i went out and bought a camera and im making a how-to-video. if you want i can send it to you for a couple of bucks.
#25
RE: h/c/i
or you could just upload it to my server and so i dont have to pay anything lol. And then i can host it for everyone to download. Depending on how big the video is, you might have to leave your computer on overnight or for 2 days so i can get it.
#26
RE: h/c/i
by the way just a little update i found an entire explorer setup. Upper/lower gt40 intake complete with throttle body, iac, egr, gt40p's with everything on them to bolt right up *will be buying the trickflow spring package for 130 from summit since im changing cams* and also includes newer gt40p headers all for 500shipped to my door. Its an amazing deal!
#28
RE: h/c/i
hey 5spd gt, i was wondering if you might be able to do me a favor, this is kinda out there but i would really appreciate it. i cant find all of those model numbers on summit for some reason. So i was wondering if you could add it to a shopping cart and send me it, or just post links to everything i will need to do the h/c/i swap. Like i said, i will be using a gt40 upper and lower, gt40p's, headers, and im now thinking of a b303 cam, i will also be getting trickflow spring package for 130.
if you could post links to literally everything i need to do the swap i would really appreciate it, or if anyone has the time to that would be nice. I need every gasket, timing chain, all of it.
I just want to be able to buy everything, take it to the mechanic and have him install it all. Like many of you know, i am injured so i will not be doing the work myself, thanks so much for everyones time.
