oil pressure sender. need help ASAP
RE: oil pressure sender. need help ASAP
Put a wrench on the bottom of the sending unit and turn to the left. It'll unscrew. If you look at the bottom of the sending unit (closest end to the block) there's a nut attached to it so you can put a wrench on it.
its not hard to reach, just grab a set of wrenches and try it, i changed mine on my 88 a few months back, but that was a pain in the a** cuz of its placement.
Your kit should come with adapters to make it fit. And if all else fails, grab a pair of chanel locks and start turning it! That is how it came out of my 93 f150. It is normal thread also so righty tighty, lefty loosy!!
ccdguy
09-19-2015 05:20 PM
